CTS Turbo
Turbo Specialist
CTS Turbo is proud to announce 3 new products for the MK6 2.0TSI
TSI Cold Air intake - $299.99
Click here for ordering
The OEM air scoop works in conjunction with our sealed airbox to seamlesly force cold air into our air intake system. Air then flows through our high flow cone air filter, which utilizes an inverted cone design for maximum engine breathing. Our single piece CNC mandrel bent aluminum intake pipe with integrated MAF flange allows for smooth entry of cold air into the the engine providing peak power gains ranging from 9-15HP. All of the components included in the CTS air intake system work flawlessly together to provide increased horsepower and torque throughout the entire power band and an aggressive race inspired sound.
Product Details:
- Mandrel bent aluminum piping with black powder coating
- CNC machined MAF flange and DV relocation bung
- Reusable air filter with inverted cone design
- 4 Ply silicon connectors with stainless steel clamps
- Sealed air box with rubberized trim
- Bracketry to prevent rattling under engine torquing
- Gains ranging from 9-15HP
2.0T TSI Turbo Outlet Pipe - $199.99
The CTS Turbo TSI Turbo Outlet Pipe (TOP) is designed to replace the narrow 'pancake' pipe that comes as factory equipment on your TSI. Our Turbo Outlet Pipe features 2.25" diameter aluminium tube for optimized flow. The CNC machined billet mating flange makes connecting this TOP to your FMIC literally a snap. The billet anodized turbo to TOP connector, 2.25" coupler and premium clamps top this package off. If you're looking for a simple bolt on modification that will optimize flow and power then look no further.
Product Details:
- Mandrel bent 2.25" aluminum
- CNC machined mating flange
- CNC machined turbo outlet adapter
- Black powder coated finish
- Laser cut mounting bracket
- Designed for fitment on stock K03 turbo
2.0T TSI Throttle Pipe - $169.99
The OEM charge piping leaves something to be desired with inefficient bends, blockages not optimized for performance. The CTS Turbo throttle pipe increases the entire inside diameter to 2.5" allowing for increased flow and greater performance. The integrated water methanol bung allows for simple and straight forward installation of kits from Snow Performance. All of the components included in the CTS throttle pipe kit work flawlessly together to provide increased efficiency, horsepower and torque throughout the entire power band and an aggressive race inspired sound.
Product Details:
- CNC machined MAP flange
- DV relocation/noise pipe bung
- Integrated water methanol bung with plug
- Stainless steel clamps
