deep.mit
Thanks Deep. All of your shots look great!
Thanks man! Still a lot to learn
nice deep, love the headlights.
Did you have any problems getting your Spyder heads working? Mine were super temperamental and required some Vagcom tuning to properly work.
I can't remember what code it was, but I was having an issue where the LED DRL's would work fine, then you turn the headlights on, and the halogen bulb, the LED DRL's and the LEDs on the bumper would all turn on, but after about 5 seconds, all the LEDs would flicker, and then shut off and it would throw a headlight code.
Ended up having to turn down the brightness of the LED's through Vagcom in order to get them working right. Still using the stock halogens, planning on going to LED's soon.
Good that you were able to figure out the part about LED brightness, but thankfully nothing of that sort happened to me. Did you give Spyder folks a call? I bought the heads from Vipmotoz (reseller) and I had called them for some questions. They were pretty responsive. Both are based out of CA. I am using an HID kit btw, not the stock halogens.
Yeah called both Spyder and the seller. Seller told me to contact Spyder, Spyder told me to contact the seller. Neither were helpful. I'm on stock halogens still. Gonna upgrade soon as I start work again.
