jay745
What Would Glenn Danzig Do
I threw a cheap spacer, 90 degree, into my
K04 car, I swap to my test “stock” file when I need to pass echeck and drive around to set readiness and it’s good to go. I never remove the spacer. It’s been several years nowS
You've got it backwards.
test file = track file, 02 disabled. You won't pass emissions.
non test file = emissions readiness will pass with a spacer
You should remove the spacer for normal use, you'll eventually foul out the o2 sensor using a spacer.
