I have noticed that this car fogs up more then any other car I have ever owned. :iono:
So has everyone else here in the UK. It's a bloody nuisance. Car sits outside in temps of about 50F and then cloudy skies clear later in the day, as night falls and the temp. drops say, to 40F and low and behold i have moisture all over the inside of the windscreen sometimes as bad as having droplets towared to base of the windscreen. It's a devil to clear instantly if you want to drive away straightaway. You sit there like a 'nana and all your mates drive away their non VW cars i.e Beemers and Mazda RX8.
Also if the screen is clear then if you turn on the ignition and the fan control is on, this causes misting even though there may not be any obvious misting initially on the screen. This is also a nuisance but this can clear quite quickly if the car has been used withing the last two hours or so and there's residual heat in the engine.
Generally, our weather in the South of the UK isn't always anywhere near severe as it is in Canada and the Stated, thank goodness - I'd die if is was.!!
