siliconcenturion
I am selling a revision D 9w3 bluetooth unit! Upgrade from your 9w2 setup!
The 9w3 unit supports full phone book integration and voice control, making it much more desirable than the less-featured 9w2 unit. The revision D is one of the latest, and gives full functionality on an RNS510 or a white MFD. You need one of these two things in order to use the unit. More info on features and usage here.
This includes the unit itself, the aftermarket pass-through harness, the mic, and the bluetooth antenna.
This is the exact kit sold on ebay for 400+shipping. I am asking 270 shipped
The pass-through harness allows you to install the module without any splicing or wiring modification.
You need VAGCOM to make some slight coding changes in order to enable the unit and the steering wheel button. This link also shows how easy it is to swap a 9w2 for a 9w3.
Pass-through harness means no wire splicing. Mic also appears in this picture.
Module and bluetooth antenna.
I also have a brand-new under seat cover/fairing, mounting bracket, and fasteners I will include for 70 dollars if you care about the aesthetics of mounting the unit under the passenger seat.
