xd-data-ii
Maybe I'm nuts but it seemed like the LEDs were significantly brighter before I coded them to run as DRLs?
Depends on what coding you did.
The LEDs are the parking light circuit. Assume you just set your parking lights to be the drls and the LEDs are off when you turn on your low-beams. Maybe picking other byte 18 settings will set them brighter. Will need to know you full setup
My passenger side bulb has/had a VERY slight intermittent flicker. It popped up after they were on for about 30 seconds and seems to have gone away after driving around for a bit. What could cause this?
Try pushing the connectors together harder. Also try undo the connector and replug it in making sure it is very tightly jammed together. I had a similar issue and was just playing with the connector sorted it (even though if feel like a difference was made).
