Came off my 2012 Mk6 GTI TSI 6speed, the flywheel and pressure plate have about 60k on it, I have 2 clutch disc, 1 is the one with about 4K miles on it lightly used never launched and held stage power just fine, the second one has about 56k miles on it in which worked fine on stock boost but was slipping on anything above stage 1. I have finally upgraded to a southbend stage 3 so I no longer need this. There is some surface rust because I accidentally sprayed it with water, but it rubs right off.
100$ will get it all plus shipping anywhere in the U.S. This is a great bargain if you plan on going to stock or resurface the flywheel and throw a stage 3 drop in southbend clutch and you can run ko4 all day .
