corrado917
Actually, you're wrong. Hatchbacks are in fact the worst possible aerodynamics this side of a U-Haul box truck. Sedans, especially ones with properly sized/located spoilers have much less turbulence and better continuity of laminar air flow. The air flow across the body is what creates the smooth mechanical leverage arm that leads to increased traction. Having your airfoil with an un-tapered, abrupt end, causing chopping in the air flow isn't good for anything. Among other things, as the air fills the partial void/vacuum- it slows down. This is why pick up trucks have shitty gas mileage at speed and why air plane wings aren't shaped like VW Golfs.
Don't get it personally,but it's wrong.Since Hatchbacks can actually afford better aerodynamics than sedans in many cases. The shallow slope of the hatch leading to a sharp cutoff and (relatively) small vertical rear face give a very optimal aerodynamic profile. The steeper slope of a sedan's rear window causes airflow to separate from the body of the car, creating drag.at the end of the day,either GLI or GTI still in the VDub Family.
