Golf 2.5 Belts Tensioners Pulleys Diagram
MLue1
Since most 2.5s are coming due for belts, tensioners and pulleys I though I'd post this diagram to help Identify them.
Cheers
OrangeSpy
Is there a recommended KM to switch these out?
Sent from my SM-A520W using Tapatalk
MLue1
IDK but all the rollers have bearings, we just past 205K km (+125K miles) so I don't owe those bearings anything, I placed an order to replace them all including the belts. I rev it prety hard at times and with the SRI coming soon I'd rather do it earlier.
It is a bit expensive to replace all of them, so if you budgeting you could remove the belts and spin the rollers, if you sence any rough spots as it spins you need to order up that particular part.
You could hold out and wait for it to start to "howl",... but that's not me.
Your car, your choice.
Jet DH
Any videos anywhere about changing them? Got a quote for $190 from local dealer service dept.
Edit - Found some on you tube (duh) - was asking if any on here.
Seems pretty straight forward. Any advice from anyone that has done it themselves - in the driveway? Looks like
taking off the fender well seems to be best approach.
Save myself about $150 too.
Jet DH
I got some belts from NAPA (made by Gates) and went to install them today.
PAIN IN MY PHUKIN ARSE!!!
I could not for the life of me get the serpentine belt on.
NAPA part no NBH 25050418
I had the idler pulley clocked ALL THE WAY OPEN and that f#kk1n belt was about 5mm short. 2 and 1/2 hours after making up new cuss words I gave up.
I can get the OE belt on and off in like 5 mins. Yes I know it is prolly stretched a bit, but DAGGUMM it would just not go on.
Anyone have the length of the belt? I figure the last four numbers are the length.
FlowMK6
17.80x1063mm
Jet DH
OK -- So if OE belt is 1063 and the NAPA belt is 1076 -- Why the Flippin heck wont it go on my car?
Jet DH
That will help for sure.
What I can tell you is that I can get the belt over all the pulleys except 2 or 3. Depending if I am over the or under the motor.
And I have the tensioner clocked all the way open/loose.
I have the fender panels off and the wheel for space to work.
I'll pm you my email.
FlowMK6
No need for email, I will share it to everyone :)
Here is a pdf with all the informations you will ever need, enjoy :
https://1drv.ms/b/s!ArY8ezVu0AA1geYGSnew3OUwcDadZw
Jet DH
So that locking pin - is there an allen key I can stick in there? Pretty much what it looks like.
MLue1
A bit late to help above Member but I found some Belt info that may help. Some times the parts people will give you the wrong belt, coz they assume the belts fit all the 2.5s, see the NOTES for correct Belt.
MAKE MODEL ENGINE YEAR RANGE NOTES
VW Beetle FWD 2.5L (BPR) 2006 - 2010 Uses 5PK935
VW Beetle FWD 2.5L (BPS) 2006 - 2010 Uses 5PK935
VW Beetle FWD 2.5L (CBTA) 2012 - 2014 Uses 5PK935
VW Beetle FWD 2.5L (CBUA) 2012 - 2014 Uses 5PK935
VW Beetle Cabrio FWD 2.5L (BPR) 2006 - 2010 Uses 5PK935
VW Beetle Cabrio FWD 2.5L (BPS) 2006 - 2010 Uses 5PK935
VW Beetle Cabrio FWD 2.5L (CBTA) 2013 - 2014 Uses 5PK935
VW Beetle Cabrio FWD 2.5L (CBUA) 2013 - 2014 Uses 5PK935
VW Golf FWD 2.5L (CBTA) 2010 - 2014 Uses 5PK925
VW Golf FWD 2.5L (CBUA) 2010 - 2014 Uses 5PK925
VW Golf Wagon FWD 2.5L (CBTA) 2010 - 2014 Uses 5PK925
VW Golf Wagon FWD 2.5L (CBUA) 2010 - 2014 Uses 5PK925
VW Jetta FWD 2.5L (BGP) 2006 - 2007 Uses 5PK925
VW Jetta FWD 2.5L (BGQ) 2006 - 2007 Uses 5PK925
VW Jetta FWD 2.5L (CBTA) 2008 - 2010 Uses 5PK925
VW Jetta FWD 2.5L (CBUA) 2008 - 2010 Uses 5PK925
VW Jetta FWD 2.5L (CBTA) 2011 - 2013 Uses 5PK935
VW Jetta FWD 2.5L (CBUA) 2011 - 2013 Uses 5PK935
VW Jetta Wagon FWD 2.5L (CBTA) 2008 - 2009 Uses 5PK925
VW Jetta Wagon FWD 2.5L (CBUA) 2008 - 2009 Uses 5PK925
VW Passat FWD 2.5L (CBTA) 2012 - 2014 Uses 5PK935
VW Passat FWD 2.5L (CBUA) 2012 - 2014 Uses 5PK935
VW Rabbit FWD 2.5L (BGP) 2006 - 2007 Uses 5PK925
VW Rabbit FWD 2.5L (BGQ) 2006 - 2007 Uses 5PK925
VW Rabbit FWD 2.5L (CBTA) 2008 - 2009 Uses 5PK925
VW Rabbit FWD 2.5L (CBUA) 2008 - 2009 Uses 5PK925
Video on "How the Tensioners Fail"
Video on Removing the Belts
