How are the owners liking them? Really thinking about picking up a set but I always worry about aftermarket LEDs
Do it. There is a one year warranty on these.
If you do not have access to coding should you just get the lights no fog?
Attempting to piece together all the information on which light will come on with which switch/reverse. Before I swap the tails, I just want to make sure I fully understand what will change.
If you can't code ....
And you get the non fog version all will be well and is fully plug and play (both white reverse lights). You will have the jazzy startup flicker however - coding will get rid of that.
With the rear fog version you will have the red fog light come on when you put the car in reverse (plus the above flicker). If the red reverse light doesn't bother you then it's fine and is fully plug an play.
If you don't want the red light to be on in reverse you need to code the car to disable it.
jazzy start up flickr? how exactly do you get rid of that?
Code and remove the resistors.
They should just sell a cheaper version then without the resistors. But i think the resistors are as simple as just unplugging them right?
Just installed my LEDs. Any tips you guys have for keeping the resistors in place other than the double sided 3m tape? They still wiggle a bit. Other than that �� pretty solid fitment.
