blueshirts0819
Stock dampers?
Even so, you'll be fine
I will be using stock dampers.
Stock dampers?
A little.
It's the same with the H&R and Neuspeed springs.
From what I've seen on here, the Eibachs actually have an even drop.
The car sits level (if you look at the side skirt), but due to the different heights of the front & rear fenders.....the front will have a larger gap than the rear & APPEAR to be lower in the back
(if that makes sense)
Someone else had pics of a CW GTI, but I can't find it...but these will do:
http://www.golfmk6.com/forums/showthread.php?t=5961
IN most cases the lower you go on stock coils the faster they will wear. Just my 0.2 but I figure by the time my coils are beat I'll get aftermarket anyway.
I did not notice any reverse rake with my Neuspeed springs. In fact, it was the opposite. The front dropped about 1/8" more than the back, giving a slight fwd rake to the setup.
Isn’t that your tire size?Yes, they are. My tire off-set is 225/40/18.
