Hi, guys.
Long time reader here but first time posting.
Need your help with my MK7 GTI 2014 with 57300 km on the clock.
The car drives but it is struggling to shift gears. It loses power between the gears and after a minute or so, it gives me two alerts saying (1) “Error: Transmission. Reverse not possible.” and (2) “ACC and Front Assist not available”.
Interestingly enough, those issues are cleared after turning off/on the car. However, the moment I drive it a bit, the clunky transmission problem persists until the error message comes up again.
Also, I am getting no errors when the car is in P but the moment I bring it to D, loads of transmission codes are popping up on my OBDeleven. I will list the codes below.
I already changed the battery to an AGM one, and did the adaptation using OBDeleven. No success!
Also cleared the codes and scanned it again… basically same behaviour - No errors when in P but loads of transmissions codes when in D or N.
Have you come across this behaviour? Would you be able to shed me some light, please?
I will head to the garage early next week but it's been hard to manage my anxiety here.
Thanks, folks!
OBDeleven log:
02 Transmission
System description: DQ250-6F MQB
Software number: 0D9300040S
Software version: 4311
Hardware number: 02E927770AQ
Hardware version: H52
Faults:
P072C00 - Stuck in Gear 1
Intermittent
P072D00 - Stuck in Gear 2
Intermittent
P072E00 - Stuck in Gear 3
Intermittent
P073A00 - Stuck in Gear 5
Intermittent
P072F00 - Stuck in Gear 4
Intermittent
P174A00 - Valve 3 in partial transmission 1
Electrical error
Intermittent
P174E00 - Valve 3 in partial transmission 2
Electrical error
Intermittent
P179D00 - Cooling oil valve
Electrical error
Intermittent
P271100 - Unexpected Mechanical Gear Disengagement
static
Priority - 0
Malfunction frequency counter - 2
Unlearning counter - 255
P079700 - Pressure Contr.Solenoid C
Stuck On
Intermittent
Thanks, folks!
OBDeleven log:
02 Transmission
Faults:
Intermittent
Intermittent
Intermittent
Intermittent
Intermittent
Electrical error
Intermittent
Electrical error
Intermittent
Electrical error
Intermittent
static
Priority - 0
Stuck On
Intermittent
