cchase__
I am so very confused as to what happened..
My motive initially was to remove the multi function control trim to either wrap it or to replace it (now i want to replace it with the black golf R one).
I will explain what happened.
I did not disconnect the battery (if this matters)
I then pried at the little clips in the back of the steering wheel then took off the air bag
Without disconnecting the airbag cables i removed the trim
i didn't end up wrapping the trim so i put it back on
then i put the air bag back on
Next thing i know is the horn doesn't work??
Is it possible i installed it back wrong?
The paddle sifters, controls, and lights still work.
Also there is no "click" when pressed.
Please help, it's very annoying because it doesn't make sense!
