Is my exhaust pipe supposed to have an air leak?
edwardnese
https://photos.app.goo.gl/QizPS0e7RYF296ES2
In the video around :20 secs you can see liquid (it is water just snowed the day before the vid) running along the exhaust pipe (i think its the exhaust pipe?) being sprayed out. This tells me there is an leak in the pipe and i was wondering arent the exhaust pipe connections supposed to be fully welded all around the circumference? Any help is appreciated
lilonespaz
i second that. man that exhaust clamp looks bad. Granted i dont have winter here but live on the coast in Florida and my clamp only has minor rust on it.
GreyGti1990
Mines rusted to crap too. Think I'll also buy that replacement clamp!
These New England winters are brutal. I try to minimize the rust whenever possible. Really want to coat my undercarriage.
NotMoneyGuy
Likewise up here in the heavily salted Toronto area. My '12 GTI has now been through almost seven full winters and almost 123,000 km / 76,300 miles. The clamp looked like this today on the hoist when my trusted mechanic pointed it out as about to fail sooner or later.
I will pick up a genuine VW 1K0253141N real soon and have it at the ready in the car.
snobrdrdan
former GTI owner
A heads up when trying to replace that clamp.....the bolt/nut will probably be rusted/seized up
You'll most likely have to cut the middle of the 2 bolts, in between the 2 "ears" on the clamp, to remove it. That'll separate/loosen it once you cut those in half
See pic:
GreyGti1990
That clamp is CRUSTY. Mine doesn't look that bad yet... you win Canada, you win
lilonespaz
That Canadian clamp should be replaced ASAP
i think they just need the throw the whole car away actually
NotMoneyGuy
Thanks all. Picked one up this morning.
damagi123
NotMoneyGuy
Good tips, thanks. It snowed again last night, so no real desire to crawl around on the driveway till the nice spring weather eventually comes around, so the project is on hold.
I have been advised to wait until it breaks off because it will be a lot easier to install it.
Otherwise the Sawzall will be the "off" and the 1/2" socket (fits tighter than 13 mm) will be the "on". At this time there are no issues with the sounds, so it would be nice to delay the install until we are out of salt season.
