jay745
Acadias Daddy
Figured it was about time I start one of these.
Anyways, for those of you who don't know my, the name is Jay. I'm from Chicago. Before this starts sounding like a personal ad I'll get to the car lol.
Bought the car new in May 13, 6 speed manual 30 miles.
Mods:
Mods:
APR Stage 1 Carbonio intake - installed 9/24/13 (SOLD)
Unitronic Intake - installed 1/17/15
APR Stage 1 ECU tune - installed 9/24/13(removed)
APR Stage 2 ECU tune - installed 6/9/14(removed)
HPA (75a) dogbone mount - installed 5/10/14
Neuspeed Turbo Outlet Pipe - installed 6/24/14 (SOLD)
R8 Coils & NGK Plugs - installed 5/30/14
S3 Short Shifter - installed 7/4/2014
Neuspeed FMIC - installed 7/18/2014(removed)
RSR Clutch - installed 8/1/2014
42DD Shifter Bushings - installed 8/1/14
GFB DV+ - installed 8/25/14
42DD Solid Shifter Bracket Bushings - installed 10/22/14
APR K04 & 3.1 Software - installed 10/15/14
Clutch Stop - installed 12/08/15
034 Billet Pendulum - installed 3/14/15
034 Trans mount - installed 4/19/15 (SOLD)
034 Motor mount - installed 4/19/15 (SOLD)
Tyrolsport master bracket - installed 4/19/15
Stoptech Front/Rear Brake pads - installed 5/21/15
Tyrolsport Brake Stiffening Kit - installed 5/21/15
Motul 5.1 brake fluid - 5/21/15
AWE S3 TOP - 7/28/15
Neuspeed Charge Pipe (SOLD)- 7/28/2015
BFI Stage 2 Motor Mount - installed 2/27/16
BFI Stage 2 Trans Mount - installed 2/27/16
Stoptech ST40 BBK - installed 3/16/16
ECS Clutch Bleeder Block - installed 3/16/16
Integrated Engineering Catch Can - installed 4/21/16
Fluidampr - installed 4/25/16
Snow Stage 2 Water/Meth - installed 6/12/16
BSH Throttle Body Pipe - installed 6/12/16
Tyrolsport Radiator - installed 8/7/2016
INA Throttle body spacer - installed 8/7/2016
Snow 60 tb spacer meth nozzle - installed 8/7/2016
Snow Meth solenoid - installed 8/7/2016
Wavetrac LSD - installed 8/14/2016
AEM W/M Filter - installed 8/21/2016
Snow 2.5 gallon resevoir - installed 8/21/16
Stoptech slotted rear rotors - installed 4/22/17
Braille #11 Lightweight Battery (11.5lbs) - installed 6/14/17
PolarFIS - installed 7/10/17
Raxles Race axles - 9/1/2018
Eurojet intercooler - 9/8/2018
Dieslgeek shaft bushings - 10/23/2018
Dieselgeek Super Slider - 10/25/2018
Setrab Oil Cooler - 5/25/2020
Mocal Sandwich Plate- 5/25/2020
Urotuning Coolant Coupler - 5/20/22
Exhaust:
EuroJet Turbo Back - installed 2/15/14
42DD O2 Spacer - installed 3/21/14 (Removed)
Suspension:
Koni Yellow Struts/Shocks - installed 6/9/14 - Removed 7/1/18
Eibach Pro Kit Springs - installed 6/9/14 - Removed 7/1/18
034 Strut Mounts - installed 6/9/14 - Removed 7/1/18
H&R 24mm Rear Sway Bar - installed 1/23/15
Powerflex Caster kit(anti lift kit) - 8/28/2015
H&R 26mm Front Sway Bar - 8/28/2015
Tyrolsport Deadset Kit - 8/28/2015
Whiteline Front Endlinks - 9/12/2015 - Removed 4/7/19
Unibrace UB - 9/22/2015
Passat Control Arms - 1/09/2016
SuperPro Front Lower Control Arm Bushings - 1/09/2016
KMD Tuning Lower Front Subframe Brace - 1/30/2016
034 Rear Endlinks - 5/14/2016
Eurosport X Brace - 6/10/2016
Tyrolsport Rear Deadset - 8/7/2016
Unibrace RB - 4/9/2017
KMD Tuning Front Control Arm Brace - 5/13/2017
Voodoo13 Rear Toe Arms 4/6/2018
Powerflex Black Lower Control Arm Bushings - 5/29/2018
Powerflex Black Rear Upper Control Arm Bushings 5/29/2018
Powerflex Black Rear Trailing Arm Bushings - 5/29/2018
Mk5 Rear Upper control Arms - 7/17/2018
Vorschlag camber plates - 7/17/2018
Eibach multipro r2 coilovers -7/17/2018
Steinjager Front Endlinks -4/7/19
Eurosport front firewall brace - 3/29/21
Ecs rear trailing arm brace - 4/20/21
Tires:
Sumitomo HTRZ3
BFG Rival-S
Hankook Ventus RS3
Hankook Ventus RS4
Cosmetic/Misc:
35% Tint
Clear Side Markers - installed 11/9/13
Euro Switch - installed 1/20/14
GTI Door Inserts - installed 10/1/13
Yellow Fog LaminX - installed 5/9/14
PIAA H8 Yellow fog bulbs - installed 5/9/14
Klii Color Matched rear emblem insert
Klii German Flag steering wheel emblem insert
DeBadged GTI from rear hatch - 6/27/14
Depo LED Black Cherry tails - 6/12/14 (came off lambs car +10 scene points)
AWE Boost Gauge - installed 5/17/14
AWE Boost Tap - installed 5/17/14
VW Seatbelt pads
Unplugged Soundaktor - 8/6/14
OEM Front Lip - 9/18/14
LED SideMarkers(deautokey) - 9/29/14
LED License Plate Bulbs(deautokey) - 9/29/14
LED City Bulbs(deautokey) - 10/15/14
PIAA H7 Extreme White headlight bulbs - 12/28/14
TWM Spooky Weighted Shift Knob - 1/9/15
Weathertech floor mats 1/16/15
Rennline fire extinguisher mount cleanchem extinguisher - 7/31/15
Oem euro aspherical mirrors - 8/21/15
OPD Sequential Turn Signals & Puddle Lights - 4/2/16
OEM Golf Debadged Grill - 5/29/16
Rennline gas pedal with riser plate - 3/27/18
Vag Com:
Disable Seat Belt Chime
DRL's off - Euro Switch
Push to Talk as Mute
Disable Horn when locking
Comfort Turn Signals set to 5
Gauge Sweep
Windows up/down with key fob
Pending Install:
PTP Turbo Blanket
Accusump
Thanks for reading. Will be posting reviews of some of the things to come along with pics.
Mods:
Mods:
Exhaust:
Suspension:
Tires:
Sumitomo HTRZ3
BFG Rival-S
Hankook Ventus RS3
Hankook Ventus RS4
Cosmetic/Misc:
35% Tint
VW Seatbelt pads
Vag Com:
Gauge Sweep
Pending Install:
PTP Turbo Blanket
Accusump
