Anybody else running a Joying head unit? I have the 8" screen with physical knobs.
If so, I have a couple questions:
- How do I change units from metric to imperial?
- Where can I tap a lead to signal my amp?
- How do I get Torque Pro to sync with OBD2 dongle?
Thanks
1. You can't. You can change to farenheit in the settings, but that does not apply to the widget, so I just removed it. If will show farenheit up top, but mine shows like 850 degrees.
2. I tapped the blue antenna wire and it's working fine. There is another amp wire that I know some people have used, but that needs to be turned on in the settings. There are some conversations about 1 wire on the other not working for some people, but the blue antenna wire worked for me.
3. I don't know, I realized how junky the Torque Pro app was and decided not to bother. I may give it a try, but the app looks like junk. There's a little CD with the dongle that has an instruction file.
