Driving me crazy, Kessy system on 2013 GTI
Both remotes open and unlock doors but touching the handle to lock and unlock stopped working on both drivers/passenger at same time. Hatch still works keyless and car still starts with keys in my pocket. Just seems both handles died. Read a few online tricks, nothing seemed to work. New batteries, no difference.
This is what a VCDS scan shows:
Address 05: Acc/Start Auth. (J518) Labels: 5K0-959-434.clb
Part No SW: 5K0 959 434 B HW: 5K0 959 434
Component: VWKESSYPQ35GP 085 0902
Revision: 00085000 Serial number: 0178205623
Coding: 030C0C
Shop #: WSC 01357 011 00200
ASAM Dataset: EV_KESSYPQ35G A02013
ROD: EV_KESSYPQ35G_VW01.rod
VCID: 346D07859F4F8FE268-8060
3 Faults Found:
1052936 - Touch Sensor on Exterior Door Grip; Driver Side
B116B 29 [008] - Signal Implausible
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 4
Fault Frequency: 10
Reset counter: 141
1052939 - Touch Sensor on Exterior Door Grip; Driver Side
B116B 13 [008] - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 122
Reset counter: 142
1053195 - Touch Sensor on Exterior Door Grip; Passenger Side
B116C 13 [009] - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 68
Reset counter: 102
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 5K0 959 703 D HW: 5K0 959 703 D
Component: Tuer-SG 007 2101
Coding: 0001168
Shop #: WSC 01357 011 1012552
VCID: 356B3A815C3596EA5F-8060
1 Fault Found:
00930 - Locking Module for Central Locking; Rear Left (F222)
008 - Implausible Signal - Intermittent
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 5K0 959 704 D HW: 5K0 959 704 D
Coding: 0001168
VCID: 36693D8D41339DF256-8062
1 Fault Found:
00931 - Locking Module for Central Locking; Rear Right (F223)
Any ideas greatly appreciated!
Coding: 030C0C
3 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 10
Reset counter: 141
Freeze Frame:
Fault Priority: 4
Reset counter: 142
Freeze Frame:
Fault Priority: 4
Fault Frequency: 68
Reset counter: 102
Coding: 0001168
1 Fault Found:
Coding: 0001168
1 Fault Found:
