Frank@KMD1
KMDTuning is proud to present a street/track clutch kit for the daily driver and weekend racer!
Kit features:
-Modified Audi TT-RS Pressure Plate with custom made ceramic-metallic disc for a full contact surface.
-Unlike some clutch kits on the market that use a wider face disc which will cause an overhang, the KMD kit was designed to work with the full diameter of the Audi TT-RS pressure plate.
-The ceramic-metallic disc is also thicker than other kits which will offer a longer life from the clutch.
Why did we go with ceramic-metallic instead of organic? Here's just a few reasons why we decided to be different.
-The eight ceramic-metallic trapezoidal-shaped buttons have a very low inertia.
-Organic facings tend to fade as they heat and a ceramic-metallic button clutch is designed to operate at high working temperatures without fading.
-Button type ceramic-metallic plates use only about 50% of the flywheel and pressure plate surfaces during clutch engagement. This improves heat transfer by as much as 100%.
-Ceramic-metallic button-style clutch facings are very durable and have the unique ability to grab better as it heats.
-Button type pads do not warp during use unlike full ring metallic or organic linings.
-Button type pads prevent scoring of the friction faces, as they allow the dust worn from the friction surfaces to be thrown clear of the clutch areas.
-Ceramic-metallic materials are less sensitive to grease and oil contamination than organic asbestos based linings.
Kit Contains:
-Ceramic-Metallic Clutch Disc
-Pressure Plate Bolts
-Metal OEM Slave Cylinder
-Slave Cylinder Bolts
Application Guide:
-MK5 FSI / TSI
-MK6 TSI
-Beetle TSI
-CC TSI
-MK6 Golf R TFSI
-MK7 TSI Gen 3
$1149.99
FREE SHIPPING!
"This Clutch kit is built to order and ships between 2-3 days"
Message me to order!
Kit features:
Kit Contains:
Application Guide:
-MK5 FSI / TSI
-MK6 TSI
-Beetle TSI
-CC TSI
-MK6 Golf R TFSI
-MK7 TSI Gen 3
$1149.99
FREE SHIPPING!
