Let's hear it: Builds
GtiDom25
Alright men, let's hear it. I wanna hear the builds you all have going or plan on building up. On my mk6 I've currently got a beautiful 3inch full turbo back BillyBoat exhaust with a resonator delete, Nuespeed p-flo air intake, forge spacer(yes, I know there's no power gain. I simply just enjoy the sound), I have a stage 2 custom tune I'm pushing 300hp, a beautiful ~25 boost. I also have a weighted M1 Abrams shift knob that just makes shifting orgasmic. This summer I'll be replacing my clutch and probably getting some upgraded brakes and rotors. Let's hear it.
Laimface
Alright men, let's hear it. I wanna hear the builds you all have going or plan on building up. On my mk6 I've currently got a beautiful 3inch full turbo back BillyBoat exhaust with a resonator delete, Nuespeed p-flo air intake, forge spacer(yes, I know there's no power gain. I simply just enjoy the sound), I have a stage 2 custom exhaust, I'm pushing 300hp, a beautiful ~25 boost. This summer I'll be replacing my clutch and probably getting some upgraded brakes and rotors. Let's hear it.
How are you seeing 25psi of boost when the factory MAP sensor maxes out at 23psi (1 bar sea level, 1.5bar boost)? Or are you living up on a mountain somewhere so the pressure ratios are different?
GroceryGTIer
The map can go to 23, the car can still boost above that.
Although I'm seriously doubting the 300 hp part. Stage 2 isn't making 300... At least not to the wheels.
Edit: the OP didn't specify stage, so I'll wait to see if it's stock turbo
smanierre
Guess i'll post my current setup and future goals.
Current:
42DD Turbo Back exhaust
Cobb Big SF Intake
GFB DV+
034 Street Density Motor Mounts
Future:
ECS Pendulum (Have, installing this weekend)
HPA 75A Puck (^)
BFI Stage 4 Clutch
Peloquin LSD
iAbed RMS (Have, waiting for clutch and LSD)
Fluidampr Crank Pulley
Turbo Outlet Pipe (Spulen probably)
Charge Pipe (CTS or Neuspeed probably)
ETS Mitsubishi Intercooler
Aquamist HFS-4
Stratified Pro tune
This is all just to prepare for eventual big turbo setup with a goal of 450whp.
Edit: Any recommendations or change advice welcome.
riceburner
i'm in way over my head lol. follow my build in the signature link!
Engine:
APR K04 kit
SPM Catted DP
SPM 2.5" Midpipe
APR RSC catback
Full unitronic intake
Rev9 intercooler
Upgraded 'pancake pipe' (turbo outlet to intercooler)
BSH Throttle pipe
034 Catch can setup
GFB diverter valve
R8 coils
HP24 spark plugs
Fuel filter upgrade
Magnetic drain plug
Remove hood blanket (for such boost noise!)
Treadstone MAF airflow straightener
PTP Lavaflow downpipe/turbo hot side wrap
DEI gold wrap around intake
Brakes:
Stoptech pads
R1 concept rotors
Braided brake lines
Tyrolsport brake stiffening kit
Drivetrain:
APR DSG Tune
034 Engine mounts
HPA Dogbone mount
Tyrolsport deadset front subframe kit
B-cool 'Coolflow' filter housing
Suspension:
VWR Springs
Adjustable sway bar endlinks
KMD Tuning front stress bar
Powerflex antilift front kit
Aurora spherical control arm bushings and toe arms
Unibrace (main underbody brace)
Wheels:
2016 golf R wheels, center spokes wrapped
Nitto NT555 G2 tires
Interior:
Leather GTI seat swap, restitch accent threads in red
redlinegoods alacantara shift boot w/ red stitch
redlinegoods alacantara e-brake handle w/ red stitch
Alacantara steering wheel wrap
Jetta GLI e-brake BOOT (leather w/ red stitch over the plastic 'boot'
BFI DSG Knob (red leather)
Custom alacantara wrap lower dash (in progress)
Upgraded OEM radio to RCD-510
Carbon fiber trim pieces
'GTI' seat emblems for handles
New floormats
MOJO Mats
Red LED floor 'ambience lighting'
Paddleshifter extentions
LEDs everywhere
Redlinegoods leather armrest
Sound deadening where needed
USB port
Vent mounted boost gauge
APR steering wheel badge
Handmade leather wrap/red stitch shifter console surround
Euro cupholder
Exterior:
Euro front lip, colormatched
Golf R sideskirts
DutchParts front splitter
Maxton designs golf R side skirt extensions/splitters
Maxton designs rear spoiler extension
Wrap lower grille surround from grey to white
Remove splashgaurds
Paint lower grille and foglight grills
New foglights, tinted
3000K fog bulbs
R20 led headlights
5500K hid kit
PS24Y switchback turn signal bulbs
LED R20 tail lights
Smoked side markers
Black VW badges
debage 'gti' emblems
Carbon fiber license plate frame
LED license plate lights
30% window tint
Full polish/paint correction
Rear wiper delete
Towhook license plate bracket
Golf TDI skidtray/aero plate (for full font subframe coverage and air scoop to cool turbo)
G2-Paint kit to repaint red calipers
Weight loss:
Deka ETX16L battery (~40lbs stock to ~6lbs now!)
Remove spare tire, replace with inflator and plugs
smanierre
Did you notice any difference with the MAF straightener? I have a 3" MAF housing and sometimes my AFRs get a little crazy, wondering if this would help to get a better reading from the MAF.
Laimface
Do you not have the map for the COBB intake? That'll explain your AFR shitting itself. Go Stratified as you get a free map with your AP
smanierre
I have the map for the Cobb intake. I'm gonna go stratified once I get all my parts on. For the most part it's fine but when I'm maintaining speed around 65-70 the afr fluctuates between 13-16. I'm guessing it could be turbulent air giving the maf a bad reading, especially since it probably wasn't designed for a 3" housing so the straightener may help
Sent from my XT1635-01 using Tapatalk
lilonespaz
What show is this?
Also My Build
CTS Turbo Intake.
Beluga Racing Turbo Back Exhaust (Catless NON Resonated)
034 Dogbone Insert
Cobb AP with Stratified custom "Stage 2" Tune
Euro Tails
Conti DW Extreme Tires
Not to much.
Next on the list is...
Projector Headlights
Motor/Trans/Dog Mount
Wheels
Possibly in later future
Coilovers
Intercooler
TOP and TBP.
Laimface
If you're cruising with little load the AFR can go all over the place, if I'm tapping the throttle on and off to maintain speed the AFR can go past 35 for split seconds. if your AFR does that under load then you may have a concern.
riceburner
You know what, I mis-spoke in that list (just copied from my build) - i had actually bought that with intention of installing but found that the unitronic intake actually has one before the MAF sensor already. So in other words, my maf readings are probably fine (havent confirmed)
lilonespaz
mikeleemk6
Too much to list right now but here are some pics. Instagram: @mk6bagged
