^thanks for the reply!
First off, it sounds like my car is probably pulling some timing right now, and dialing in the meth alone on the 93 tune would add some power, yes?
I have no control over when the jets come on; assuming both automatically turn on at the same time.
The pump is 1amps:220psi actually. The MAFU controller appears to control start/full parameters, with the max being 220 psi when it sees 2.2k hz from the MAF sensor? I'm not the sharpest on deciphering the diagram, here's a link to it if interested:
https://www.snowperformance.net/product-p/60100.htm
So, i'm going to get the torque app to monitor/log... i would need to be logging these parameters:
MAF Values: See what they are without meth, then with, and THEN i will see how much air is being displaced.
That air being displaced will have an effect on the timing correction factor? At this point i should be seeing a lower timing correction factor than without meth?
Logging 02 corrections and injector constant: What #'s would I want to be seeing compared to stock? More, same, less?
Timing curve: Want to see it smoothly going up i think, as in no spikes, does not go down at peak?
Thanks again!
