Hi,
I Had a similar issue, I changed Fuel Filter, coils and plugs, and the issue always returned after a while, I even used Injector Cleaner for a while when I fill up,
mine was intermittent with no Codes, normally when the car was warmed up and I Drove in traffic it would misfire/backfire/after fire when I decelerate on the overrun or at idle.
I checked the Injectors, LPFP, HPFP, Changed DV to latest revision, all with no improvement.
I even ran logs and got it professionally diagnosed and tested, they checked Spark, timing, Fuel, vacuum, and boost leaks and everything else.
Alas I gave up, but then Carbon Build Up came to mind, so for the last week or so I would let the car warm up to operating Temp, and then on my highway commute (15 to 20 minutes) I will drive it in S Mode or M mode to keep the RPM’s at +/- 4000
This “Italian Tune Up” seemed to clear up some of the Carbon on my Intake Valves and the problem has stayed away thus far.
Try it…
