Hey guys so I recently started gaining balls to try this... I started by taking out the windshield pump and filler and I have bought all the connections to move the battery to the trunk and I bought the block off plate to remove everything for the SAI. I also bought new engine and tranny mounts to make things a bit shinier. Don't mind my nasty bay but I had a question regarding the coolant ball. I am going to make a bracket and move it where the windshield fluid pump used to be behind the bumper..
My questions are:
1) where can I buy the proper tubing to do this and connect it all back up properly?
2) what are these silver lines on top of the engine behind the coil packs going to the coolant overflow and then to other spots? How can i delete this line and re route it to the ball? And what is the other silver line going to that plugs in to the green connection by the ball?
3) when extending the electrical wires for different plugs to be re-routed, did you guys crimp or solder them?
Thank you for your time!
