vermontmk6
After over a year of problems, I pulled the k04 on my 2013 Mk6 MT Autobahn to get the car inspected. Two shops did some things right and a lot of things wrong during the install process, have posted a few times about this. Went through three DV's, blown coils, boost leaks, busted COBB CAI intake mounts, lots of little issues. As much as I'd like to work my way through a build like Hyde16's, I simply want the k04 sorted out so I can enjoy it.
I have an estimate from ECS in Connecticut to do the reinstall and put a tune on with their in-house dyno. I have a COBB turbo-back exhaust, RSR Clutch Kit w/ Sachs flywheel good to 480 ft/lbs, fresh brakes and tires. I've had every turbo/boost/intake-related engine code in the book, replaced the PCV and intake manifold, and carbon cleaned. I do not want a LSD at this time, new motor mounts, or other non-essential hardware.
I would appreciate recommendations on what I should do to the car while they are doing the following.
Reinstalling: IE k04 turbo, 3bar sensor, Neuspeed turbo outlet pipe.
New parts install: Remove OEM and install AWE intercooler, IE cold-air intake, GFB DV+, plugs (gapped to .26?), R8 coils.
What other parts should I upgrade? Turbo Inlet Pipe?
How difficult is it to check timing chain revision? I'm not sure if 2013 model even needs to be checked?
I'm asking ECS to deliver the car inspectable in Vermont. Not sure what that is going to entail but what a PITA it was to mess around with spacers that never worked.
You have all been so helpful the last few years, and I'd appreciate if you could take a few minutes and respond. I'd love to get the car down to ECS in the next week or so.
