Aries Pope
So I just took a long road trip (600 miles) to try out the new K04, but I noticed a few issues and hoping someone has a thought to how to diagnose. I have a DSG, I don't have a boost gauge, just Torque which gives straight OBD2 like MAF and other stuff, not actual MAP. But I can log. It's clear I need to invest in a cheap netbook running VAGCOM ASAP.
First off, at low RPM (2000) and higher gears (5,6) if I go WOT I hear a squeaking /chirping (presumably from the the turbo, it's a new sound) a couple times a second. (I'll have to get a video tomorrow). It's like something isn't balanced right, but I kinda worry it's a light surge. There's not much power when it occurs, then it eventually clears up and the power comes on after a few seconds at like 3000+. Mostly I just avoid it by staying low throttle until I hit 3K. It's very reproducible.
Second, a couple times shifting from 5 to 6 under near full throttle I get a loud whoosh sound and total drop in power, feels like a hard shift cuz the car bucks. I lay off the throttle and then ease back into it or drop back to 5th and it's fine again.
Third, on the drive back a few times I'd go WOT in 4th or 5th to pass a slowpoke and I watched the tach just bounce around 3K. It'd climb a little, then drop a few hundred, just fluttering there, no power, no speed increase. I was like WTF? So I let off the gas, downshifted and it cleared up, then BAM, see number 2 above as I shifted 5-6 another power issue. Something was not right. Babied it for a while, then it seemed fine again.
When I got home I pulled fault codes with Torque which said there were none!
I'm planning to try and go for a ride tomorrow with Torque logging MAF and a few other things. What should I grab? I wish I could get the boost levels from the MAP, I'll need to find a VAGCOM. I'll grab a video of the squeak too.
Since no codes I'm guessing not a misfire? Any thoughts what could be causing these issues and how to test it scientifically?
