APR stage 2 test pipe file definitely does. You’ll fail here due to too many ‘Not Ready / Incomplete’Did you check rediness with OBD11 or VagCom?
I didn't think the tune changed that.
I don’t see the point to paying for the remote solution if you plan on switching to Eurodyne. Just go to the closest shop and have them flash to stock, if you don’t have the fully loaded programs. It shouldn’t be more than 15min...
If say i wanted to pass inspection i would need a revision file or i would have to flash to stock with Stock Downpipe?
My understanding (CBFA motor in a strict state):
If it's just an OBD inspection, flash to stock and put some O2 spacers on your downpipe so that the ECU thinks everything's kosher.
If it's OBD and Visual inspection, find yourself a lenient shop first, then flash to stock and put some O2 spacers on and hope you found the right shop.
Rear only. Idk about NY now but in cali you cant even pass with that they look under your car and instantly fail you for non carb compliant exhaust regardless if you have no codes or aftermarket cat.
