01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI3
Part No SW: 5G1 920 731 B HW: 5G1 920 731 B
Component: KOMBI 104 8310
Coding: 0785020823000008010808001400000000000000
Shop #: WSC 12345 123 12345
ASAM Dataset: EV_DashBoardVDDMQBAB 009051
ROD: EV_DashBoardVDDMQBAB_009_VW26.rod
VCID: 2541449324E10FBB98-8070
1 Fault Found:
13636608 - Control Module Incorrectly Coded
U1014 00 [009] - -
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 69
Reset counter: 16
Mileage: 151107 km
Date: 2023.11.10
Time: 22:43:36
Address 19: CAN Gateway (J533) Labels:| 5Q0-907-530-V1.clb
Part No SW: 5Q0 907 530 AM HW: 5Q0 907 530 M
Component: GW MQB High 212 2265
Revision: -------- Serial number: 20051910001875 Dataset Number: V03935242HR 0001
Coding: 030000041F086800FB0002481C0E00010001050000000000000000000000
Shop #: WSC 131071 1023 2097151
GVL: 01543C0000000000400C00000000C80000000000000000000000000000000000
ASAM Dataset: EV_GatewConti 013020
ROD: EV_GatewConti_013.rod
VCID: 7CF741F7F7EB6E7397-8028
Generator:
Battery Monitoring Control Module:
Subsystem 2 - Part No SW: 5Q0 915 181 K HW: 5Q0 915 181 K
Component: J367-BDMHella H10 9070
Serial number: 4505121604
3 Faults Found:
66052 - Infotainment CAN Bus (SAE Bus E)
U0065 00 [008] - Performance
[New feature! Extended UDS fault detail is only supported by current gen. interfaces]
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 244
Reset counter: 56
Mileage: 151107 km
Date: 2023.11.10
Time: 22:55:13
Terminal 30 power supply: 12.2 V
Terminal 15: OFF
67072 - Local Databus
U1125 00 [009] - Additional Installations Detected
Freeze Frame:
Fault Priority: 2
Fault Frequency: 213
Reset counter: 16
Mileage: 151107 km
Date: 2023.11.10
Time: 22:54:04
Terminal 15: On
8782090 - Cruise Control Switch
B1154 96 [009] - Component Internal Failure
Freeze Frame:
Fault Priority: 2
Fault Frequency: 68
Reset counter: 16
Mileage: 151107 km
Date: 2023.11.10
Time: 22:54:04
Terminal 15: On
Address 5F: Information Electr.
Cannot be reached
End-------------------------(Elapsed Time: 03:34)--------------------------
