alpha3
That's all you can do is be virulent. Keep some coolant in the car for emergency use.
1ashchuckton.......I sincerely hope you're not virulent..........
...I think you meant to say, ''vigilant.''
No smoking, no milky oil, no overheating. I've had two or three oil samples evaluated and they all come back clean.Can't find an coolant leak externally yet its losing coolant.. unfortunately it might be being lost internally which is far worse. I would get the oil tested. You're not getting any unusual smoking?
Check the radiator. When I had my 20k service done, I mentioned the coolant was low. They topped it off and did a pressure check, they couldn't find anything. Around 35k miles the radiator all the sudden dumped all the coolant out. Luckily it was in my garage, so I topped it off with distilled water and made it 3 miles before it emptied and had to get towed the last 3 miles. I would take some distilled water just incase you need to top off.
If you don't have road side assistance, get it.
What coolant is everyone using?
