Rear sunroof drain plug
srivel
The left rear sunroof drain in my 2010 GTI is clogged and water is leaking into trunk. Anyone knows where the left rear sunroof drain plug located?
Picture will be helpful. Thank you!
GolNat
You can try blowing it out with compressed air.
srivel
Thank you! I found the leak in the connector between rear drain tube and sunroof. Pls see the silicon I applied around the connector and drain tube in the pic....I have to remove the wheel liner to get access to drain tube outlet. IMG_5101.jpgIMG_5102.jpgIMG_5108.jpgIMG_5109.jpgIMG_5111.jpg
