Rearview camera not working after MIB2 retrofit, help please!
pedroYUL
Location
MI
Car(s)
2015 GSW S
After a lot of waiting on tools (D-Link dub-e100, VCP, and some online help), I finally have a working MIB2STD in my 2015 GSW S TDI. Unit 3Q0 035 844B, that replaced a 5G0 035 844.
But the rearview camera (RVC) is not working, the only thing not working.
Long coding in 5F: 02 73 02 00 FF 00 00 00 51 22 00 01 00 18 08 00 1F 05 00 D4 01 20 05 00 02
Also tried these adaptations (but I don't have parking sensors):
ENG122227-ENG117496-Car_Function_Adaptations_Gen2-menu_display_pdc activated
ENG122227-ENG117500-Car_Function_Adaptations_Gen2-menu_display_pdc_after_disclaimer not activated
ENG122227-ENG117497-Car_Function_Adaptations_Gen2-menu_display_pdc_clamp_15_off not activated
ENG122227-ENG117498-Car_Function_Adaptations_Gen2-menu_display_pdc_over_threshold_high activated
ENG122227-ENG117499-Car_Function_Adaptations_Gen2-menu_display_pdc_standstill not activated
ENG122229-ENG117710-Car_Function_List_BAP_Gen2-parking_assist_0x0A activated
ENG122229-ENG117711-Car_Function_List_BAP_Gen2-parking_assist_0x0A_msg_bus Terminal 15
Anyone with experience in what could be going on, probably some other setting somewhere else? I appreciate the help.
pedroYUL
Location
MI
Car(s)
2015 GSW S
The guy that helped me remotely said that my camera is incompatible with MIB2, but I've seen people use the exact same part numbers I have.
Yes, this MIB2 came out of an Atlas, which I think has a fixed camera, but in my case the MIB doesn't even show a black screen (asking for a video signal but not getting the right one), it does absolutely nothing when I put the car in reverse.
Are there things I can try? I have genuine VCDS (latest software), VCP and arriving today also VAS5054a
pedroYUL
Location
MI
Car(s)
2015 GSW S
My parts list:
Main unit: going out 5G0035844 (MIB1, Panasonic), going in 3Q0035844B (MIB2, Delphi). Ebay for $125
Screen: out 5G0919605H, in 3G0919605H. Ebay for $100
USB jack: removed the MDI, routed and connected 5G0 035 222 E. Ebay for $49
D-Link DUB-E100 (the black one): Groovesland for $36.56
Online help from Brazil (only 1h difference): $80...I only recommend you go with this guy if you are pretty proficient yourself as he might not be able to get every single detail (adaptations) completed.
I did buy VCP, but you don't need it if you already have VCDS. No need for VAS tool or ODIS with this Brazilian guy.
Total $390.56, I say I did not too shabby.
pedroYUL
Location
MI
Car(s)
2015 GSW S
Skype: lord_wesker
I do have to say that the Component Protection fault remains, I can see it using VCDS in both the Gateway and the MIB2 unit, but the fault doesn't impede function at all.
Also, there was at least another adaptation needed to get rid of fault 1555 Check Software Version Management. I recommend downloading XaGiCo guide, the fix is there plus much much more...all you have to do is calculate the new value for this adaptation IDE02502-Confirmation of installation change in 5F
1. Use this website http://xor.pw/
2. Add current adaptation value in First Input I INPUT (hex b16)
3. Add value 51666 in Second Input II INPUT (dec b10)
4. Click Calculate XOR
5. Add the result as new value for the adaptation channel (hex b16)
6. Clear errors
jcarr
Location
US
Car(s)
2015 GTI Autobahn
Another MIB1 -> MIB2 retrofit here where the rear view camera (RVC) stopped functioning. Emblem moves to bring camera into position when in reverse, but screen does not change (current display stays, does not go black).
2015 GTI Autobahn w Fender audio. Added 3G0919605H 6.5" screen, 3Q0035844B head unit & 5Q0035726J USB port.
I've checked the 5F byte 19 setting & the IDE04307-ENG117712-Vehicle function list BAP-VPS_0x0B adaptation is (as far as I can tell) not active.
Any other thoughts? Newbie here, grasping at straws.
Thanks!
jcarr
Location
US
Car(s)
2015 GTI Autobahn
Thanks!
Followup... not sure why this worked, but I found the USB was set to "iPod" rather than "Full". That change returned the functionality of the rvc, albeit not all the time. Occasionally, the unit will need to be rebooted after the car has started in order for the rvc to function.
Odd, but working most of the time is significantly better than none of the time.
backcountry
Location
Indiana
Car(s)
GTI
Look for my thread where I was having the intermittent RVC issue. I fixed it with cleaning up a VCDS coding issue.
