I ran my canbus cable and got the codes:
8 Faults Found:
008567 - Bank 1; System Too Lean off Idle
P2177 - 000 - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 8
Reset counter: 255
Mileage: 98742 km
Time Indication: 0
Date: 2016.05.29
Time: 15:52:19
Freeze Frame:
RPM: 2503 /min
Load: 18.8 %
Speed: 102.0 km/h
Temperature: 93.0°C
Temperature: 54.0°C
Absolute Pres.: 990.0 mbar
Voltage: 13.462 V
000257 - Mass Air Flow Sensor (G70)
P0101 - 000 - Implausible Signal - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100000
Fault Priority: 0
Fault Frequency: 8
Reset counter: 255
Mileage: 97775 km
Time Indication: 0
Date: 2016.05.11
Time: 14:59:32
Freeze Frame:
RPM: 1727 /min
Load: 27.8 %
Speed: 70.0 km/h
Temperature: 90.0°C
Temperature: 50.0°C
Voltage: 13.716 V
000768 - Random/Multiple Cylinder Misfire Detected
P0300 - 000 - - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 99062 km
Time Indication: 0
Date: 2010.10.24
Time: 08:30:50
Freeze Frame:
RPM: 724 /min
Load: 17.2 %
Speed: 0.0 km/h
Temperature: 63.0°C
Temperature: 27.0°C
Absolute Pres.: 980.0 mbar
Voltage: 14.097 V
000769 - Cylinder 1
P0301 - 000 - Misfire Detected - MIL ON
Freeze Frame:
Fault Priority: 0
Fault Frequency: 3
Reset counter: 255
Mileage: 99062 km
Time Indication: 0
Date: 2010.10.24
Time: 08:30:50
Freeze Frame:
RPM: 724 /min
Load: 17.2 %
Speed: 0.0 km/h
Temperature: 63.0°C
Temperature: 27.0°C
Voltage: 14.097 V
000772 - Cylinder 4
P0304 - 000 - Misfire Detected - MIL ON
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 99062 km
Time Indication: 0
Date: 2010.10.24
Time: 08:30:50
Freeze Frame:
RPM: 724 /min
Load: 17.2 %
Speed: 0.0 km/h
Temperature: 63.0°C
Temperature: 27.0°C
Voltage: 14.097 V
000770 - Cylinder 2
P0302 - 000 - Misfire Detected - MIL ON
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 99066 km
Time Indication: 0
Date: 2010.10.24
Time: 08:34:48
Freeze Frame:
RPM: 754 /min
Load: 14.9 %
Speed: 0.0 km/h
Temperature: 81.0°C
Temperature: 30.0°C
Voltage: 13.716 V
000771 - Cylinder 3
P0303 - 000 - Misfire Detected - MIL ON
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 99067 km
Time Indication: 0
Date: 2010.10.24
Time: 13:07:48
Freeze Frame:
RPM: 1326 /min
Load: 34.5 %
Speed: 16.0 km/h
Temperature: 51.0°C
Temperature: 36.0°C
Voltage: 14.097 V
008825 - Leak in Air Intake System
P2279 - 000 - - MIL ON
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 99068 km
Time Indication: 0
Date: 2010.10.24
Time: 13:10:08
Freeze Frame:
RPM: 760 /min
Load: 15.3 %
Speed: 0.0 km/h
Temperature: 84.0°C
Temperature: 36.0°C
Voltage: 13.716 V
Readiness: 0000 0000
Looks like I have quite a few things to check
