aphawthorne
2013 Gti 83,000 miles
Title pretty much says it all.
Car went from driving totally fine to hardly running and smoking.
I did the obvious things first after learning of the cylinder 1 misfire.
Plugs & coil packs.
After those failed to fix anything I moved onto compression testing and found that there was no compression what so ever in the first cylinder.
So my question is, is it more likely that I've got a stuck open or burnt valve from carbon buildup? Or bad rings?
Any insight is appreciated when I wake up tomorrow I'm going to pull off the intake manifold and see if there's anything going on with the intake valves.
TYIA
Plugs & coil packs.
TYIA
