gti_kev
It's definietly my REVO stage 2 tune. I'm over boosting which causes it cut fuel.
Revo tune requests levels very close to 180 bar which is what causes it to cut fuel. don't get why revo gets so close to the cut off.
Hey guys,
seems to me like a boost leak somewhere but my boost gauge is reading right, Its at 21inhg, peaking at 24ish, and holding around 18psi. BUT, last night i felt it bog out once on third gear right when it hit peak. I thought it was weird so i downshifted back into third and went WOT again, but everything was normal.
Now, this morning i tried passing a semi in third gear, same thing, it bogged/sputtered out, went normal, then bogged/sputtered again. So i thought to myself, fuck, maybe i gotta pull over cause its happening again. So as i was pulling over, i tried it to see if it'll happen again, and nope 3rd gear pulled through smoothly.
Kind of seems like fuel cut, like when trying to brake boost too much, and it just cuts fuel. Its exactly that feeling.
I doubt its the coil packs since I'm not getting a CEL, i know what the feeling is when its misfiring. I have new coils and R8 CP's.
I'll lift it up tonight and check my IC hoses, TBH, and TOP. I popped the hood and got under the car a bit but everything seemed good. Of course can be different under boost with pressure.
What do you guys think? anything else i should look for?
I'll find some VAg-com but in the mean while, ill appriciate the feedback.
Got track this weekend so i gotta get this fixed. I'd hate to waste a track day.
Hey guys,
