tjasko
My R got a ton of things done at the shop. Timing belt/water pump replaced, replaced MAP sensor due to corrosion from washing the engine bay, installed the 42DD shifter cable support bracket to prevent the cables from rubbing on the down pipe, and fabbed a custom bracket for my charge pipe to stop it from hitting the radiator fan.
Prob did my timing belt too early (~70k), but better sooner than later.
Def cover up the MAP sensor if you're gonna wash the engine bay. Lesson learned hahaha
