Stationary Right Cornering Lamps aren't installed in the Golf, so it looks like the 09 coding is messed up. You may have a bulb check issue beyond any "cold lamp diagnosis" coding tweaks if they aren't resistor style bulbs.
Please edit that to include the complete module ID, or better yet, post the complete Auto-Scan. If you have the original coding please include it.
thanks for helping is the full scan
VCDS Version: Release 10.6.1 (x64)
Data version: 20100831
Monday,25,October,2010,19:08:27:59633
Chassis Type: 7N0
Scan: 01 02 03 08 09 15 16 17 19 1C 25 42 44 46 52 55 56 77
VIN: WVWFV7AJXBW052358
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
1C-Position Sensing -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (CCT) Labels: None
Part No SW: 1K0 907 115 AP HW: 1K0 907 115 AA
Component: 2.0l R4/4V TFSI 0020
Revision: AAH18--- Serial number:
Coding: 0403010A1C070160
Shop #: WSC 01357 011 00200
VCID: 74C910B06EC9
No fault code found.
Readiness: 0000 0000
Address 02: Auto Trans Labels: 02E-300-0xx.lbl
Part No SW: 02E 300 053 N HW: 02E 927 770 AL
Component: GSG DSG AG6 511 2208
Revision: 05151112 Serial number: 00001005050789
Coding: 0000020
VCID: 20612CE08AB1
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AT HW: 1K0 907 379 AT
Component: ESP MK60EC1 H30 0105
Revision: 00H30001
Coding: 114B600C492700FC880E06E992210041310800
VCID: 8429C070BE69
Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
Part No SW: 5K0 907 044 BT HW: 5K0 907 044 BT
Component: Climatronic H15 0709
Revision: 00003001
Coding: 0000000002
ASAM Dataset: EV_Climatronic A01006
ROD: EV_Climatronic_VW36.rod
VCID: 7EDD32985085
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 1K0 937 087 L HW: 1K0 937 087 L
Component: BCM PQ35 H 104 0615
Revision: 00104 AE
Coding: 6D180A3F80272A040088008165004904404C0086534D8D60648020200040
VCID: 3A55FE880C2D
Part No: 1K1 955 119 F
Component: Wischer 10071 21 0512
Coding: 009795
4 Faults Found:
02235 - Stationary Cornering Lamp (Left) (M51)
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 4
Fault Frequency: 1
Reset counter: 112
Mileage: 2790 km
Time Indication: 0
Date: 2002.14.12
Time: 19:04:18
Freeze Frame:
Term 15 On
Voltage: 12.90 V
ON
ON
Term 50 Off
OFF
OFF
02236 - Stationary Right Cornering Lamp (Right) (M52)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 112
Mileage: 2790 km
Time Indication: 0
Date: 2002.14.12
Time: 19:04:19
Freeze Frame:
Term 15 On
Voltage: 12.95 V
ON
ON
Term 50 Off
OFF
OFF
02395 - Parking Light Right Front (M3)
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 2
Fault Frequency: 1
Reset counter: 112
Mileage: 2790 km
Time Indication: 0
Date: 2002.14.12
Time: 19:05:00
Freeze Frame:
Term 15 On
Voltage: 12.65 V
ON
ON
Term 50 Off
OFF
OFF
02394 - Parking Light Left Front (M1)
014 - Defective
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 112
Mileage: 2790 km
Time Indication: 0
Date: 2002.14.12
Time: 19:05:01
Freeze Frame:
Term 15 On
Voltage: 12.65 V
ON
ON
Term 50 Off
OFF
OFF
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Part No SW: 5K0 959 655 B HW: 5K0 959 655 B
Component: AirbagVW10G 021 0706
Serial number: 003C4R00RDXX
Coding: 00003042
ASAM Dataset: EV_AirbaVW10SMEVW360 A01012
ROD: EV_AirbaVW10SMEVW360_VW36.rod
VCID: 3957E184092B
Driver's Airbag Crash Sensor:
Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Fahr.V H01 ----
Serial number: 3572MSME1E4A0355ZZZZ
Passenger Side Airbag Crash Sensor:
Component: S.Sens.Beif.V H01 ----
Serial number: 3582MSME32230256ZZZH
Driver's Rear Airbag Crash Sensor:
Component: S.Sens.Fahr.H --- ----
Serial number: 3512QSME0C4C6511ZZZW
Passenger's Rear Airbag Crash Sensor:
Component: S.Sens.Beif.H --- ----
Serial number: 3522QSME36155350ZZZK
Driver's Front Airbag Crash Sensor:
Component: F.Sens.Fahr --- ----
Serial number: 35527SME46113322ZZZ+
Passenger's Front Airbag Crash Sensor:
Component: F.Sens.Beif --- ----
Serial number: 35627SME5B103322ZZZ4
Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
Part No SW: 5K0 953 507 AH HW: 5K0 953 549 B
Component: Lenks.Modul 007 0080
Revision: -------- Serial number: 90440JFO00067
Coding: 189A140000
ASAM Dataset: EV_SMLSNGKUDS A05001
ROD: EV_SMLSNGKUDS_VW36.rod
VCID: 76CD2AB878B5
MFL:
Part No SW: 5K0 959 542 HW: 5K0 959 542
Component: E221__MFL-TAS H05 0010
Serial number: 0007636
Coding: 830000
1 Fault Found:
530190 - Local Databus: Electrical Malfunction
U1030 00 [008] - Defective
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 115
Mileage: 1600 km
Date: 2001.14.29
Time: 23:23:36
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 5K6 920 871 HW: 5K6 920 871
Component: KOMBI H04 0406
Serial number: 00000000000000
Coding: 370F00
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04089
ROD: EV_Kombi_UDS_VDD_RM09_VW36.rod
VCID: F1C799A491DB
Address 19: CAN Gateway Labels: 7N0-907-530.clb
Part No SW: 7N0 907 530 HW: 1K0 907 951
Component: J533 Gateway H27 5603
Revision: H27 Serial number: 150710F2000857
Coding: ED811F0600160200000000
VCID: EDFF85D48DE3
Address 1C: Position Sensing Labels: 1Kx-919-xxx-1C.lbl
Part No SW: 5N0 919 879 HW: 5N0 919 879
Component: Kompass 001 0001
Revision: 00001000 Serial number: 1225223R9S5D06
Coding: 0000002
VCID: FEDDB298D085
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H04 0406
Coding: 000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03008
ROD: EV_Immo_UDS_VDD_RM09_VW36.rod
VCID: EAF58EC8BC0D
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 5K0 959 701 B HW: 5K0 959 701 B
Component: Tuer-SG 009 2117
Coding: 0001076
VCID: 3147D9A4D15B
Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 74 3001
Revision: 00H17000
VCID: 3147D9A4D15B
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 5K0 959 702 D HW: 5K0 959 702 D
Component: Tuer-SG 009 2149
Coding: 0001076
VCID: 3449D0B02E49
Address 55: Xenon Range Labels: 5M0-907-357-A.lbl
Part No SW: 5M0 907 357 C HW: 5M0 907 357 C
Component: AFS-Steuergeraet 0142
Revision: 00H04000 Serial number:
Coding: 1446940
VCID: 3449D0B02E49
Part No: 7L6 941 329 B
Component: AFS-Lst.-Modul l 0004
Coding: 00000022
Component: AFS-Lst.-Modul r 0004
Coding: 00000022
Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
Part No SW: 1K0 035 180 AC HW: 1K0 035 180 AC
Component: Radio Prem-8 H13 0043
Revision: -----26S Serial number: VWZ4Z7K1150821
Coding: 2500040004
VCID: 61E769E4C13B
Address 77: Telephone (J412) Labels: None
Part No SW: 7P6 035 730 C HW: 7P6 035 730 C
Component: TELEFON H05 0440
Revision: 1B001001 Serial number: 00007668394431
Coding: 0A00000000010100
ASAM Dataset: UHVNA A01007
ROD: UHVNA_VW36.rod
VCID: 3245D6A8D45D
1 Fault Found:
9458195 - Control Module for Cellular Telephone
B1052 13 [000] - Open Circuit
Freeze Frame:
Fault Status: 00000000
Fault Priority: 0
Fault Frequency: 0
Reset counter: 0
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
End ---------------------------------------------------------------------
