VAGCOM HELP!!! Fault code 00984 & 00985
Darkmkvigti
Hello having problems fixing the coding for this issue (see below) need help cause its driving me insane only having one reverse brake light and dimmer out light in the rear!
Thursday,29,July,2010,23:54:34:54296
VCDS Version: Release 10.6.0
Data version: 20100630
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 1C 25 42 44 46 52 55 56 77
VIN: WVWEV7AJ8AW134566
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
1C-Position Sensing -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
77-Telephone -- Status: OK 0000
Address 01: Engine (CCT) Labels: 06J-906-026-CCT.clb
Part No SW: 1K0 907 115 AM HW: 1K0 907 115 AA
Component: 2.0l R4/4V TFSI 0030
Revision: AAH07--- Serial number:
Coding: 0403010A18070160
Shop #: WSC 01357 011 00200
VCID: 71C7079711C1
No fault code found.
Readiness: 0000 0000
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AM HW: 1K0 907 379 AM
Component: ESP MK60EC1 H45 0108
Revision: 00H45001
Coding: 114B600CC92500FE881006EA931F00413008
VCID: 7DDF2BA75D99
Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
Part No SW: 5K0 907 044 BD HW: 5K0 907 044 BD
Component: Climatronic H14 0608
Revision: 00003001
Coding: 0000000000
ASAM Dataset: EV_Climatronic A01001
ROD: EV_Climatronic_VW36.rod
VCID: 6EFD1CEB00FF
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 1K0 937 087 F HW: 1K0 937 087 F
Component: BCM PQ35 H 103 0541
Revision: 00103 AE
Coding: 69180A3F90272A040088008570000D0041040086534D8D60648020000000
VCID: 3449CE832E53
Part No: 1K1 955 119 E
Component: Wischer 01090 21 0501
Coding: 009795
2 Faults Found:
00984 - Left Tail Light (M4)
007 - Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00100111
Fault Priority: 2
Fault Frequency: 4
Reset counter: 120
Mileage: 15813 km
Time Indication: 0
Date: 2009.14.27
Time: 23:04:00
Freeze Frame:
Term 15 Off
Voltage: 12.05 V
OFF
ON
Term 50 Off
OFF
OFF
00985 - Right Tail Light (M2)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 120
Mileage: 15813 km
Time Indication: 0
Date: 2009.14.27
Time: 23:04:00
Freeze Frame:
Term 15 Off
Voltage: 12.05 V
OFF
ON
Term 50 Off
OFF
OFF
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Part No SW: 5K0 959 655 B HW: 5K0 959 655 B
Component: AirbagVW10G 019 0706
Serial number: 003C4D07C81H
Coding: 00003042
ASAM Dataset: EV_AirbaVW10SMEVW360 A01012
ROD: EV_AirbaVW10SMEVW360_VW36.rod
VCID: 3957FFB70931
Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl
Part No SW: 1K0 953 549 CF HW: 1K0 953 549 CF
Component: J0527 056 0111
Coding: 0000532
VCID: 78D13AB372BB
Part No: 5K0 959 542
Component: E221__MFL-TAS H05 0010
Coding: 00000130
Shop #: WSC 00000
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 5K6 920 870 B HW: 5K6 920 870 B
Component: KOMBI H05 0206
Serial number: 00000000000000
Coding: 370F00
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04040
ROD: EV_Kombi_UDS_VDD_RM09_VW36.rod
VCID: 3245C89BD447
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 AA HW: 1K0 907 951
Component: J533 Gateway H07 0081
Revision: H07 01 Serial number: 310809F1003029
Coding: E9811F06001602000000
VCID: 66ED64CB280F
Address 1C: Position Sensing Labels: 1Kx-919-xxx-1C.lbl
Part No SW: 5N0 919 879 HW: 5N0 919 879
Component: Kompass 001 0001
Revision: 00001000 Serial number: 1225223T67EM04
Coding: 0000002
VCID: FEDDACABD09F
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Component: IMMO H05 0206
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03004
ROD: EV_Immo_UDS_VDD_RM09_VW36.rod
VCID: 3245C89BD447
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 5K0 959 701 B HW: 5K0 959 701 B
Component: Tuer-SG 009 2107
Coding: 0001076
VCID: 3147C797D141
Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
Part No: 1K0 909 144 H
Component: EPS_ZFLS Kl. 74 2901
Revision: 00H17000
VCID: 2F43C1EFC775
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 5K0 959 702 B HW: 5K0 959 702 B
Coding: 0001076
VCID: 3245C89BD447
Address 55: Xenon Range Labels: 5M0-907-357-A.lbl
Part No SW: 5M0 907 357 C HW: 5M0 907 357 C
Component: AFS-Steuergeraet 0142
Revision: 00H04000 Serial number:
Coding: 1446940
VCID: 3449CE832E53
Part No: 7L6 941 329 B
Component: AFS-Lst.-Modul l 0004
Coding: 00000022
Component: AFS-Lst.-Modul r 0004
Coding: 00000022
Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
Part No SW: 1K0 035 180 AC HW: 1K0 035 180 AC
Component: Radio Prem-8 H10 0034
Revision: -----19S Serial number: VWZ4Z7J1116004
Coding: 2500040004
VCID: 61E777D7C121
1 Fault Found:
02635 - Tuner Not Enabled/Activated
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 40
Mileage: 15064 km
Time Indication: 0
Date: 2009.14.14
Time: 15:40:23
Address 77: Telephone (J738) Labels: None
Part No SW: 1K8 035 730 C HW: 1K8 035 730 C
Component: Telefon H08 6600
Revision: 00008000 Serial number: 20389520222643
Coding: 412100
VCID: 29772FF7F991
End ---------------------------------------------------------------------
pvivino
Is this with stock tail lights and stock bulbs? If so then it is a bad ground or bad contact on the bulb. Make VW fix it under warranty. You can try some di-electic grease on the bulb contacts.
If this is an aftermarket bulb then that is the problem.
Drunknfoo
Year 2009? and an invalid month? Did you try just clearing the code to see if it comes back?
If you are using the OEM tails try coding byte18 to 03 then back to 00 to get it back to stock/default. (this is assuming you made changes to this particular byte)
If you ever ran an autoscan prior to any vagcom changes, you should be able to confirm what was changed and restore the coding.
Good luck
Darkmkvigti
I sent him a pm earlier in the week and response yet. I wonder what he did to fix the problem, this is killing me.
reddogy
Hello,
I have a problem with this error 00984 - Left Tail Light (M4) 007 - Short to Ground.
Everything started after a friend (mechanic at the local VW service), in his free time has mounted fog lights, warning lights and door speakers in the rear doors. After these changes the error occurred. I deleted code with VCDs but the error appears again.
I checked the connections between the back door and the car body, the bulb socket in the back door and I noticed no problem.
What god is that?
I do not get along with the idea that when I turn on the ignition the yellow light bulb appears in the dashboard.:mad:
  • VCDs.txt
