BrianWithGolf
Here is the dealer recommended Maintenance Schedule (Mileage-Based)
Prices vary based on dealer and location. There are other services that are not included in this Schedule such as Water Pump/Timing Belt, Coolant Flushes, etc.
I also recommend changing your oil every 7,500km rather than just every 15,000km but that's personal preference.
15,000 KM
Battery: Check
Brake Pads: Check Thickness and Disk Brake Condition (front and rear)
Coolant level and frost protection: Check
Engine: Change oil and replace oil filter
Engine and Engine Compartment Components: Check for leaks and damage, check transmission, final drive, drive shaft bolts
Headlights: Check adjustment
Lighting: Front and rear lights, luggage compartment lighting, turn signals, hazard warning lights, daytime running lights, curve lighting
Rear Window: Check clean nozzle functionality (if applicable)
Service Interval Display: Reset (if applicable)
Service Sticker: Update date for next service and in windshield driver’s side door pillar
Tires: Rotate Front to Rear
Windshield washer and wiper blades: Check for damage and function, check fluid level.
30,000 KM
Battery: Check
Brake Pads: Inspect brake system and shock absorber for leaks and damage. Check Thickness and Disk Brake Condition. Check Brake Fluid.
Dust and Pollen Filter: Replace (if applicable)
Tires: Check tread depth, condition, wear pattern, and pressure on all tires (including spare)
45,000 KM
Battery: Check
60,000 KM
Battery: Check
Body: Visual Inspection for corrosion
CV Joints: Check for leaks and damage
Door checks and mounting pins: Lubricate
Exhaust System: Check for leaks, damage and secure fittings
Interior lighting and glove box lights, cigarette lighter/power outlets, horn and all warning lights: Check
Power Steering: Check oil level
Ribbed V-belt: Check Condition
Spark Plugs: Replace
Sunroof Panoramic Sunroof: Check, clean lubricate (if applicable)
Test Drive: Check braking, kick-down, steering, electrical, heating and ventilation, air conditioning, and handling.
Tie rod ends: Check for excessive play, check boots
Transmission: Automatic: Change fluid and filter
Transmission: DSG: Change fluid and filter
Underbody Sealant: Inspect for damage
75,000 KM
Battery: Check
90,000 KM
Battery: Check
105,000 KM
Battery: Check
120,000 KM
Battery: Check
135,000 KM
Battery: Check
150,000 KM
Battery: Check
165,000 KM
Battery: Check
180,000 KM
Battery: Check
195,000 KM
Battery: Check
205,000 KM
If you have made it this far congratulations!
If anyone has any prices and would like to share that would be great.
15,000 KM
Battery: Check
30,000 KM
Battery: Check
45,000 KM
Battery: Check
60,000 KM
Battery: Check
75,000 KM
Battery: Check
90,000 KM
Battery: Check
105,000 KM
Battery: Check
120,000 KM
Battery: Check
135,000 KM
Battery: Check
150,000 KM
Battery: Check
165,000 KM
Battery: Check
180,000 KM
Battery: Check
195,000 KM
Battery: Check
205,000 KM
