you could always order a set of swift springs and use them on the st shocks, a few users on here have changed their springs on their koni and H&r coilovers
Check my sig.. I just tracked for the 1st time last weekend and came back thinking I'm not stiff enough for tracking, although very nice for dd.
Not bad, but the only thing that bothers me is why are you running 215 on 9" width and also why did you go with a stiffer front sway bar. Shouldn't it be the opposite where you want more stiff in the rear so it causes less understeer? Btw do you by any chance have the vcds?
There can be reasons for choosing 215's, such as better gas mileage, higher top speed (less rubber on the ground) and cheaper tires although for me it was purely visual (a semi-stretched look) although I will probably go back to 225's when it's time to replace them.
My sway decision was based on threads in the forum. I admit not to have tested different combinations yet. I just think it might be difficult to notice a difference unless you're tracking. I'm probably going to set the rear hard and determine if it feels much different.
I don't have a vcds, sorry! I do know someone in South San Fran who might make himself available... I can ask.
I run a Hotchkis 27 mm in the rear. $200 from Amazon, try it first before investing in anything else.oh i see, the reason why i asked bec when i went tracking i somehow bumped into a guy who has a mk5 and his car is straight up race prepped with roll cage etc etc lol. He told me i should go 25mm front & 27mm rear. He's running 27mm all around.
ehh south sf is quite far. thanks though.
Yea... I would prefer some linear springs. I want to give the XTAs a try but then why not spend $600 more for some Bilsteins. I'm 26" FTG and my right CV axle is hitting the frame when taking some turns on Thunderhill.
https://www.youtube.com/watch?v=m0J5FpJZWMg
