P
plac
Guest
I see. I'm in a 2010 though which has the noise pipe rather than the soundkator from what I'm reading.
ah true, soundaktor only includes 2011-2012's.
Ok fellas. You need to Vag com the microphone sensitivity and turn it up to at least +5db.
I did this test and adjusted up and then put it back to -2db which was my default. I had a friend help by calling him and bothering him. I conducted this test on the street and at varying speeds up to about 70mph. Solution is to leave at +5db or higher. We figured we were not raising the sensitivity of the mic, but raising the volume level of noise it would record. So now if I don't speak the caller can not tell i am even on the line because the mic only come on when it detects a louder noise e.g.. your voice instead of the small background noises. Try it out!!
so wait, yours was better at -2db but you're saying people should put it to +5db?
I believe he was saying he raised it from -2 to +5 and back down again to see if there was a difference. He determined that at +5 its the best balance between noise and voice transmission.
How does one go to that menu?
EXACTLY! Like i said guys, the menu options says mic sensitivity, I am not sure what it is doing as far as raising or lowering sensitivity, I just know changing to +5db worked for me and I called everyone who use to complain and they were surprised, the feedback was all positive and a few even said they had no idea I was driving.:w00t:
You go to Telephone and select adaptation and scroll down the drop down list and select microphone sensitivity.
Only had one complaint with mine and that was before the SoundaKator was removed. The bluetooth in my wife's Jetta seems a bit bad, so I will defiantly go in and see if I can adjust it in hers. Might play with mine just to do it though.
Did you test settings in between -2 and +5? Or did you just try those two??
My 2010 Golf with 9W2 works great. I once did a 50-minute call driving on the Interstate with my iPhone 4. I did have to slow down to around 55 mph though. At higher speeds, the wind noise gets in the way even with all windows closed.
