The headliner on my dads crown vic with 335k miles is in better shape
stop whining and just replace dat shit wit gucci or lv print
Solution seems simply.
Don't live in Florida.
That does seriously suck, if they don't handle it (or next time it happens) I can't imagine it's that awful expensive to fix. It's less than 4 hours to replace the entire thing and it doesn't need to be replaced most likely, just re-adhesived up. What's body shop labor rate down there? $70? $250-300....yeah, not cheap but if you do get stuck with the bill, better than thousands.
dAT humidityI've had a few VWs in the past. A 2002 Jetta, a 2007 GTI, and now my 2011 GTI and all three have always had this problem prematurely happen. The GTI and Jetta both occurred after 3+ years of ownership, but I literally just paid off this car in full, and purchased the title for it after barely 3 years of leasing it and this happens. I'm 25 days outside of my bumper to bumper warranty and of course this just has to happen. I've contacted VWOA prior to visiting a dealer, because this is obviously going to be a continuing problem through all the generations. Considering mileage is below 24.5K and I'm not too far outside of the bumper to bumper, I'm hoping they'll cover it. I can't believe that they still use the same cheap ass glue or whatever they're using in production. Such garbage. I could see if the car was 5+ years old, but c'mon!
Is this an easy DIY or something you have to do at a shop? How much does it cost to fix? My cousins 2002 Jetta has this issue..
Gf just took her mk5 jetta to get done about 2 months ago. They charged her $125 I believe and knocked it out in a day. I'm sure there's some DIY instructions out there on how to do it.
Ft.Lauderdale huh? Why haven't you come to our meet yet then?
http://golfmk6.com/forums/showthread.php?t=63165
lol. But I recently installed interior LED's on another local's car that he recently bought preowned. 2010, and his is sagging in the same place, he's also got sagging around the front dome lights. Pretty much anywhere where the headliner has a cut or opening. Surprisingly he didn't know about it until I pointed it out.
He has a csg gti so maybe it has to do with the darker colored cars? :s
Is this the same meet that used to hang out behind the Fort Lauderdale Ale House on Tuesday nights? If so, I used to go there all the time, and was around when it was a SFLMKV meet up.
And I think heat is a factor for sure. Humidity likely as well, which only adds to the heat index. Dark cars absorb heat as opposed to reflecting it. My MKV was black magic pearl, so this theory does fit the bill, but my MKIV was silver, so I dunno?
Received word from VWOA that the headliner and a few other tidbits will be fixed at their cost.
Only VW would have this problem and not bother fixing it even though it was known on the mk4 and mk5 cars. Pathetic. For all the vehicle testing VW does in Florida, they sure can't seem to design a car to hold up to this weather...Wow, I have never seen this on a modern vehicle, <10 years old.
diy took me and a friend who is experienced with re-doin mk4 headliners. but u hafta take off or at least unclip all the plastic trim on sides (order a buncha those airbag tabs that insert into the trim because they will all snap coming out. mk4 b pillar tabs are the exact same if u go to a junkyard instead of ordering em), remove visors, handles, and disconnect all the lighting. pulling the panel from the trunk = no problem. but, putting it back in, u hafta be very careful not to scrape it on all the plastic trim, unless u fully remove it. i jus unclipped it halfway and let it hang, lookin back tho i shouldve jus removed it completely. will take an hour or so to remove the panel.
overall took us like 6 hrs cuz we kept running into lil issues with plastic clips n whatnot. hadda get a new passenger side a pillar cuz the plastic vent was so brittle it broke when removing the pillar. so beware if ur car has been out in the sun for yrs.
did mine with like a sorta alcanterra type material, color black. looks nicer than oem i think but not to extreme to standout if i sell later.
