Really? I think they look perfect!
I am afraid that with a couple hundred more miles, they will settle another 1/4 inch which would put me at that height of eibach pro-kit, if I wanted a pro-kit thats what I would have bought.
so the ones you mentioned above, as well as the axle bolts is all they'll need then? (if they remove the axle)... or just mention to them to change only the one-time use bolts?
that hardware kit you posted is a bit pricey... I think it's around $50... the only bolts that Bud mentioned in the "ask a VW parts guy" thread said to replace were the axle bolts, and that's if they remove the axle...
Did you get an alignment yet?
Before the alignment, my driver's side sat a little higher than the passenger side!
My only concern is their fitment with the 2.5L Golf.
-I know these are safe with the stock GTI struts but what about us 2.5'ers?
-And I keep reading how TDIs have a "sport suspension" as well but the vw site says otherwise....states that the 2.5 and tdi have the same struts.
I have a 2-door DSG GTI. I am going to order the DG springs for the 2-door manual GTI. I think it will sit a little lower than if I use the springs for DSG one. The DSG weighs 24.4 lbs more then the manual. Do you this will work?
Ha ha! Thanks.I have a 2 door DSG as well and bought the ones for the DSG. I'm having them installed Thursday so I'll let you know how the turn out. Pray for no front rake!
I did get an alignment day of install, and every parameter was almost dead center after some adjusting.
I always thought drivers side was suppose to sit slightly higher with no driver, then when you add driver weight, it normalizes.
I guess I am overreacting, I just didn't think I would get nearly 1.5" drop, which is what it is on the front, only .75" in rear. I suppose if I used the DSG versions, the drop would be very slightly less on front.
I just ordered the strut spreader bit from metalnerd.com, this $15 tool probably would have saved me close to an hour in labor cost.
More pics:
