snobrdrdan
former GTI owner
I guess I'm always the guinea pig.
I bought a set of the VW DriverGear springs for a TDI 4 door w/DSG. I have a 4 door GTI w/DSG. The weight difference is ~20lbs. between the cars.
Eibach makes them for VW, but they are NOT the "Pro-Kit" springs.
These springs are linear (like OEM). The "Pro-Kit" springs are progressive type springs.
Part numbers:
2 door Manual, 2.5, GTI, or TDI = 5K3071677A
2 door DSG, GTI or TDI = 5K3071677B
4 door, Manual, GTI or TDI = 5K4071677A
4 door, DSG, GTI or TDI = 5K4071677B
BOUGHT FROM: www.keffervwparts.com
Parts needed for install: (REQUIRED ONES IN BOLD -- others are optional & removed during install)
Rear:
1. Lower Control Arm Bolts, N-106-107-02, 2 needed
2. Lower Control Arm Nuts, N-101-064-02, 2 needed
Front:
1. Drive Axle Bolt, WHT-002-795, 2 needed -- (IF REMOVING AXLE BOLTS!!!)
2. Stabilizer bar connecting link nut, N-015-081-6, 2 needed
3. Front lower control arm nuts, N-103-320-02, 6 needed
4. Strut lower bolt, N-909-548-02, 2 needed
5. Strut lower nut, N-101-064-02, 2 needed (same nut as used on rear shock lower nut)
6. Strut upper bolts, N-101-277-07, 6 needed
7. Strut assembly rod nut, N-910-216-01, 2 needed
8. Strut Bearings, 6N0412249C, 2 needed
MISC tools needed:
1. Fwd HUB puller (rented at O'Reillys, Evertough 67032)
2. Spreader Socket (VW tool # 3424)
3. Spring Compressor (rented at AutoZone)
4. Open Socket (VW tool # 3186)
5. Torx L-wrench T45 or 7mm allen (for strut shaft)
6. Suspension limiters (VW part number 000-071-501-A)
7. 24mm 12-point socket (for axle bolts)
8. 14mm Triple Square bit (for strut pinch bolt)
9. Torque wrench
10. 2 foot breaker bar (used to get the additional 90 degrees on the front axle nut)
DIY install with pics:
http://www.golfmk6.com/forums/showthread.php?t=67825
or
http://forums.tdiclub.com/showthread.php?t=273002
Anyways....they're supposed to only be for the Golf, but they fit the GTI as well (I ran them on my MKV as well).
They don't "slam" the car, but it does get rid of most of the ugly wheel gap.
Nice slightly firmer ride, but waaaay better handling than the stock springs and you still use the stock dampers...all while keeping your suspension parts under warranty
I'm still waiting for them to "settle" I suppose, but this was right after I installed them....I happened to park next to a stock GTI (4 door DSG) and took some comparison (iPhone) pics....you be the judge:
Comparison...
Other pics....just 2 days after installing....
STOCK:
EIBACH PRO-KIT:
Part numbers:
Rear:
Front:
MISC tools needed:
9. Torque wrench
or
Comparison...
STOCK:
EIBACH PRO-KIT:
