Golfr20
Okay, so again I start the saga of DSG worries. This time there's a bit more than just the dodgy change here and there and it not reacting in the way that I would like.
Here are a few of the issues I'm experiencing:
1. Clunk - the DSG will clunk from gears 4-3 a d 3-2 (sometimes 2-1) under braking. This is only in drive mode as it seems lazy at selecting lower gears. Something new it has started doing is clunking from park to drive, drive to neutral etc, but this has only started within the last couple of weeks.
2. Stuttering/jerking - This is something that seems intermittent as I didn't notice it before, either that or again, is getting worse. What I mean by this is when creeping in gear 1 or reverse, it will start to jutter as if holding on a bite point (but slipping slightly). It seems to pick up after a few seconds, but is considerably worse in reverse.
3. Excessive feedback - when going back down the gears in drive, you can feel every gear cycled in a relatively harsh manner. Again, this is something that seems to have got worse over say 6 months and has become more and more noticable.
4. False neutral - this is something I've experienced maybe 3 times in 8-9 months so not a major issue drivability wise. The only thing is I know this can be a sign off issues to come.
My question is should I be looking at the mechatronics first, then the clutches or both? I am holding out hope for a pure mechatronics issue as when performing a reset (the one where you hold down gas pedal etc) things smoothed up entirely and all issues subsided. But are there any other ways of knowing?
The car only has 50,000 so the clutches would have had to have taken a beating this early to be that broken surely?
Any assistance would be great, car had DSG service about 6 months ago (4k later than it should have had it's 40k service, but there was record fluids had been changed) and VW said they carried out an adaptation (not sure if they did or not).
Thanks!
Thanks!
