acewayne
Random question. I don't air out that often. Went to air out and noticed my rear driver side didn't go as low as it should. As in there was still tire showing when it used to tuck wheel. I jacked the car up to see if it was resting on anything or caught on something multiple times but came up with nothing.
I had bought a daily and started working on that and kinda left it alone for a bit. Aired it out yesterday and noticed the rear passenger side is doing the same thing now. Both sides in the rear don't air out like they used to (tucking wheel). They both show tire now. I'm not sure what it could be at this point. Seized up shocks? Any ideas?
I have airlift performance front and rear fyi.
Update. For some reason when I checked to see if there was something holding the car up in the rear I didn't thoroughly inspect the shocks. Turns out the locking collar on the rear driver side came loose and the shock managed to keep spinning and lengthening itself.
In the picture I spun the locking collar back up to where it should be, which was equal to the passenger side. Dropped the control arm, unbolted the shock, spun it back up, put everything back in, and all was back to normal. Tucking wheel again and probably rides a hell of a lot better but I'll find that out tomorrow.
