$320 WITH spacer (shipping not included)
you will need to run wiring for the controller. AEM has a PDF on the controller and what wires do what
-Aem progressive controller (pre/full spray by boost)
-Snow performance pump
-solenoid
-check valve
-2 gallon tank (already tapped w/low level sensor)
-Aem inline filter
-2 nozzles (100CC and 315CC)
-2 nozzle holders (snow performance)
-Tee fitting
-line (may need more depending on the way you set yours up)
-USRT spacer
you will need an LED (few bucks) for low light signal
that's about it. system works flawless. I was able to run 93 octane file on 91 pump fuel.
-solenoid
-check valve
-Aem inline filter
-Tee fitting
-USRT spacer
