Mchandler6
Do you have a factory camera installed?
He says he has the OEM pop-up camera installed already.
You are actually able to see music on your phone, even playlist and recently played via Bluetooth on these units. It is just a matter if your phone supports it or not.
just got mine in and the dynaudio fix (unplug the battery) worked fine for my aussie mk6 golf R
Some earlier posts suggest disconnecting the factory Bluetooth module to prevent confusion during pairing. Is this as simple as pulling a connector on the module or is there more to it than that?
Interesting.. Is that the case with Android phones? Pixel in my case.
hello everyone. i'm really excited about this head unit and found one on ebay (version B). i have a 2011 GTI with the RCD 510 and i have the OEM pop up rear view camera. just wanted to make double sure what is needed for the camera to work, and if any other adapters (if required) for everything to work perfectly
I'm also wondering about this??
I got mine after a week in the mail through DHL.
Got the box opened immedietly and first thing i noticed was how well the unit was packaged. Mind blowingly good!
Second. Noticed that the unit is OEM you can tell marks on the screw tabs from prior vehicle install.
Thridly... Took the RCD 510 out, and installed the RNS 330 with no issues. Powered right away, and first thing i noticed was how much better the sound from the speakers came... on the same radio frequency as the 510. Its not a placebo effect something really is different with these units. I have read similar comments about them elsewhere.
So far everything works as it should, the steering wheel controls work, the Apple Car play thing works perfecly. Only thing that i notice is you no longer can see on the MFD what is playing like it did before.
The phone audio is exceptional as well. ON my RCD i could never use the bluetooth because the people on the other side of the line could never hear me. With this apparently sounds crisp and clear go figure considering the MIC is on the faceplate not by the mirror above.
Next up add... back up camera and im done. Finally have a Unit that I like and LOVE!.
yeh i had the rns-510 before and you could tell the difference in audio straight away, its more lively and clearer in sound.
