Not long ago I picked up a used '12 GTI. About 2500 miles into my ownership, the drain bolt started leaking. I figured it was about time for an oil change anyway, so I picked up a new (19mm) bolt and washer from the dealer. It leaked immediately.
What I had on the car was a T45 Torx bolt with a hollow crush washer. I replaced it with a standard 19mm bolt and alloy washer at my local dealer's recommendation.
For those that have been through this, is it worth it to retry the Torx drain bolt / washer combo (new of course), or should I just seal the pan until I have time to replace it? If i do replace the pan, has this issue been rectified, or will I need to worry down the road?
Attached is a pic of the new and old bolts for reference.
P.s. I torqued the bolt to 22 ft lbs, and slightly beyond when it immediately leaked.
