Abbott Martin
More than a couple people have seen this too. Unfortunately everything gets buried lmao.
People have described it as a pulsing, about 50 RPM.
That looks about right. Hard to eye ball it
The idle is a bit odd. Feels like a cat purring- revs sound as if they're going up then settling, almost like a cat purring. The tach isn't indicating much but it's not smooth.
Back when I did my first carbon cleaning around 85k miles (lots of highway miles), I was pretty stunned at the difference in how the car drove. I've put on another 30k of more mixed city/highway miles since then, and feel like it needs it again. Another thing to check are the misfire counts, I have a few random misfires that show up at least once per driving cycle if not more, and that is another indicator for needing carbon cleaning.
If you did the carbon cleaning after going V2.1, question for you (and perhaps Arin).
I'm getting a fairly consistent surge/flutter sound and hesitation from about 2500 RPM to ~3100 RPM in 4th gear, and my thought is that it could be from carbon buildup reducing volumetric flow rate at that rev range, thereby pushing the turbo compressor into the unstable flow region creating surge-like flutter sound. The problem is less prevalent in 3rd gear since it spends less time in that rev range due to the gobs of torque...
Does this ring a bell for you, did you notice anything similar?
Arin what's the deal with the odd idle behavior? It doesn't feel normal. By normal I mean the way any car I've ever been in idles.
I think the point is that most people don't have the problem. I don't for example. My idle is smooth and no different from stock. So for those like you that have this issue, you might need to discover the common thread.
I also have noticed that, along with many others, but yeah as Revolver66 said, the topic just gets buried
I'm getting Stage 2 tomorrow and have a tablet in my dash to run torque, I'll do some runs this weekend when it's sunny.Has anyone else run any acceleration runs using Torque Pro(non hand actuated stopwatch lol) timing app?
I'm thinking about making a new thread specifically for performance measurements like this to show the results of all this tuning we do. 0-60 and 1/4 mile times are good, but in gear measurements are much more relevant to me in showing and comparing performance of one car/tune to another.
It was too damp out last night to use 2nd gear at anything more than normal throttle, so I don't have a guarantee that these are the absolute best numbers since I started in 3rd every time, but still a very good representative of what I've got so far. Times may decrease slightly if I'm able to accelerate through the speeds instead of starting so low in the rev range. Still very good times. ?
93oct Stage 2 V2.1 used....so, who else wants to give some input before I make a thread?
Kei
Awesome, looking forward to seeing the results. Maybe run the results up to 100 while you're still stock too, if possible? Pretty awesome to see the before and after results when you can. Puts things into perspective ??I'm getting Stage 2 tomorrow and have a tablet in my dash to run torque, I'll do some runs this weekend when it's sunny.
