.64 is perfect imo, depending on the gear 20 psi around 4200. .86 will with only 7k rpm to play with would be no bueno, especially when it comes to transient response. Once I fix my meth system and get a half decent cbe I'm off to the dyno [emoji106]I'm getting the same atp gt3076 soon. I see you went with the .64 ar over the .84 very interested to see your dyno graph. Thanks for being the guinea pig
ATP offers a full solution; I got inlet piping, outlet piping, dv relocation,oil & coolant lines through them which is everything needed to make it work. I'm using the OEM n75 with eurodyne software and the car runs flawlessly.In going from your previous turbo setup, what items (besides the engine internals) have you had to have in order to get your current APT setup running correctly? Ie.. Tune, hoses?, boost controllers?, etc...
Also looking forward to dyno runs!
sub'd for future updates
[emoji106] [emoji106]sweet.
Around 1800cc/min according to the AEM flow meter. Right where it should be according to my calculation.What is your total flow?
So niiiceeeeeeDid some work on the bay, going for a stealthier overall look. Still needs some work but I think it's getting there. Looking at this you probably wouldn't guess this is a 434whp car
Yea did all the WMI stuff myself. It's been removed for troubleshooting a few times too. It's all really easy to do if you understand it and take your time, even drilling the manifold.Did u install the wm kit urself?
Few track days with them, never had an issue with fade. One day it was around 105, hot as hell, no fade even on street pads. Nothing has been replaced other than the pads. They lasted a long time, don't remember the mileage though.Question for you
How are the stoptech st40s? Have you had to replace anything due to wear? If so what mileage. Have you encountered any brake fade?I know you tracked so you would be a good person to ask.
