uglybastard
Ever since i did the install of a eurocubby i have been having battery issues, which i attribute to having a bad grounding location in my fusebox area for
how i hardwired radar detector via fusetap. luckily i have a portable battery jump pack but need to chase out this gremlin. thought i had it fixed last night but maybe not.
only other recent electrical mod that comes to mind as a root cause for this would be my RNS510, as the thing still makes noise after ignition is off, which i attribute to it powering down the internal memory.
Question is - RNS510 having the hard drive spinning for about a minute after car is turned off, is this normal? I think I have revision E?
Or, assuming i did fix the grounding issue, could it just be that my battery is toast? Or maybe its something else? my mechanic mentioned that my alternator bearing is starting to make abnormal noises (this was a year or more ago).
