greasyginzo
Order PTP Firewall blanket since my shitty stock insulation piece is falling apart
not a bad idea. i may do that too. it always hangs down.
When's the turbo going in?
grats on the N IC and going BT! def in for review.
Im stage 2 and considering F23T, and now looking at the N IC too. how do you like yours?
VERY nice, definitely NOT a fugazi.
killer, awesome to hear that. I actually really like my R IC, and it seems to boost really well for what it is and the performance/speed mods that I have.
I always wondered how the boost would change +/- upgrading to a better IC. do you notice any induced lag before the power? what do you think the change would be like for someone like me with my set up?
Lol no this not some fugazzi part!
With the stock GTI intercooler I was seeing 28psi now with the Neuspeed I'm seeing 26.5 psi but I have to log to double check that. As far as lag there is none in fact it is the opposite I feel it spools slightly quicker. Is it worth it on stock turbo over your already installed R IC? Probably and with a ko4,F23 or bigger absolutely. For anyone still running the stock GTI intercooler I think it is worth it as well between the couple hundo the R IC will cost you and then the install of a stock location IC.
interesting, cool to hear your input. dumb question, but is lower psi a good thing? I was lucky and got my R used and installed for $395. otherwise I was really looking at SPM or Neuspeed. both would be about the same cost wise as the SPM is cheaper upfront but cost a bit more to install since it is middle mount.
I still dont know which is the better of the two, SPM vs Neuspeed as far as performance. Id probably go Neuspeed because of fitment and quality.
